AoS 650pts list
Discussion in 'Seraphon Army Lists' started by Shawry, Jan 16, 2018.
  1. Shawry
    Shawry Member
    Hey guys,
    Chasing a decent 650 list if possible, my mate has only got a small amout of storm casts hence the 650pt limit.
    Does anyone have any tips?
    I have
    1 x carno
    2 x bastiladons
    20 x skinks
    60 x warriors
    10 x temple guard
    3 x rippers
    1 x skink starseer
    1 x skink priest
    1 x eternal warden
    1 x saurus scar vet on cold one
    8 x saurus knights
    1 x jade wizard
    I believe thats everything off the top of my head
    Ritual likes this.
  2. Aginor
    Aginor Fifth Spawning
    Hmpf you are 5 Guards short of a very tough list for 650 points.
    Eternal Starhost with Eternity Warden and 3x5 Guard, plus a Starpriest would be tough to beat I think. Maybe you can proxy five Warriors to play them as Guard?
    There are other options but that was the first one that came to mind.
    Ritual and Shawry like this.
  3. Shawry
    Shawry Member
    Cool I'll see if i can find more from a mate otherwise ill proxy
    Ritual likes this.
  4. Aginor
    Oh but one note about that list: If your opponent is an SCE playing a Relictor and a Celestant on foot he will probably wipe you from the board pretty quickly, as mortal wounds are Kryptonite for Saurus Guard.
    In that case I'd say you are better of with something Saurus heavy, let's see....
    This for example:
    Allegiance: Order
    Leaders
    Saurus Sunblood
    (120)
    - General
    - Trait: Thickly Scaled Hide
    - Artefact: Blade of Realities
    Skink Starpriest (80)
    Battleline
    40 x Saurus Warriors
    (360)
    - Clubs
    10 x Skinks (60)
    Total: 620 / 650
    Allies: 0 / 200
    Wounds: 61
    As you can see that list has WAY more wounds and uses the Starpriest's buffs and the Sunblood's buff for the Saurus. Which might be an advantage. It allows several tactics, some risky some less risky.
    Ritual likes this.
  5. jaggred
    jaggred New Member
    Skink Starpriest (80) - General - Command Trait : Master of Star Rituals - Artefact : Light of Dracothion Units 3 x Ripperdactyl Riders (140)
    10 x Skinks (60) -Boltspitters & Star Bucklers
    40 x Skinks (200) -Boltspitters & Star Bucklers
    Battalions Shadowstrike Starhost (170)
    Ritual likes this.
  6. Shawry
    Shawry Member
    Ended up just winning with the temple guard list due to some lucky rolls
    Ritual, Aginor and Crowsfoot like this.
  7. Aginor
    Please tell us more!
    Ritual likes this.
  8. Shawry
    Shawry Member
    Skink priest managed to snipe out his leader with some lucky bolts,
    Eternity Warden stayed close to the guards and took out a squad of liberators before this guard fell,
    The Warden was the mvp easily, he smashed out two squads of liberators with some lucky rolls.
    He rolled out 12 attacks and only 2 hit and i needed a 5+ to save and i rolled two 5's.
    When I rolled out 8 dice to hit, 6 hit and he saved 1
    I don't know what list to bring to our next 1k game,
    Thinking about the no friends list
    Scar vet on cold one
    Skink priest
    Jade wizard
    Bastildaon
    Warriors
    Ritual likes this.
  9. Aginor
    Be advised that a Jade Wizard cannot be played if you want to retain Seraphon allegiance.
    If you are ok with Grand Alliance Order allegiance (which in most cases I think you shouldn't) then you can use him.
    Ritual likes this.
  10. Shawry
    Shawry Member
    Yeah it doesnt bother me too much,
    Just unsure
    Ritual likes this.
  11. Aginor
    The upsides:
    - You can use any Order unit
    The downsides
    - No global unbind for Slann
    - No Slann spell range bonus
    - No teleporting units
    - No Command trait for the general
    - Order artefacts instead of Seraphon
    It is true that other armies have it worse though. If we had a spell lore I'd probably not even consider going Grand Alliance but yeah... it might be worth it for any army that doesn't use a Slann and doesn't want or need to teleport.
    Shawry and Ritual like this.
  12. Shawry
    Shawry Member
    Should I buy a Slann? I dont own one
  13. Aginor
    Of course!
    Slann look cool and they became quite useful support units with the GHB2017. Most 1.5k or bigger lists contain them since you can then choose either the extra spells for the Slann or the double teleport trait, and against magic armies the global unbind is awesome.
    Shawry likes this.
  14. Shawry
    Shawry Member
    oh cool Ill have to source one, all my locals are out of stock,
    Summoning wasn't changed was it?
  15. Aginor
    Based on your post above I made this list:
    I'd probably go for a Starpriest instead of the Priest because of the Spell and the Serpent Staff for the Saurus. I had to take one unit of Skinks because if you want to play Saurus it is 40 or 10, everything else doesn't make much sense. And 10 Saurus are too expensive by 20 points.
    Allegiance: Order
    Leaders
    - General
    - Trait: Master of Defense
    - Artefact: Relic Blade
    Battlemage (100)
    Battleline
    40 x Saurus Warriors (360)
    - Spears
    10 x Skinks (60)
    Behemoths
    Bastiladon (280)
    Total: 980 / 1000
    Allies: 0 / 200
    Wounds: 74
    Shawry likes this.
  16. Aginor
    No it wasn't changed, except if you count that one bataillon with the "free summoning" which is actually not summoning but a deep strike.
    EDIT: Oh and summoning get a bit better becasue our point values dropped. I'd say it has some benefits now although it is still not worth it most of the time.
    Shawry likes this.
  17. Shawry
    Shawry Member
    oh cool,
    Yeah Summoning to me has always seemed ehhh unless you have the points set aside
  18. Aginor
    Oh and about the list above: The Scarvet should be the General, not the Skink.
    Shawry likes this.
  19. Shawry
    Shawry Member
    Cheers for that
