Cleaning paint of models
Discussion in 'General Hobby/Tabletop Chat' started by Canas, Dec 6, 2019.
  1. Canas
    What's a good way to clean paint of models? I found my old Lord of the Rings models and well, they're terrible so I'd like to repaint em. Or at least the worst of em. Anyone know any good ways to clean off the paint? There's plastic and metal models.
  2. Erta Wanderer
    for the metal models you can just use paint striper. it will also get the paint off of the plastic models along with the first few layers of plastic
  3. Canas
    anything that doesn't melt the plastic models if I don't pay attention for a second?
  4. Erta Wanderer
  5. Canas
    mm, I'l see if I can get my hands on it.
    Erta Wanderer likes this.
  6. bOdziO Wolf
    bOdziO Wolf Well-Known Member
    IPA or Isopropyl alcohol is a super cheap chemical that will also help you in the process. If you are in USA, you can also do even better by using cleaners such as LA Totally Awesome or Super Clean (as given by Erta Wanderer).
    Usage is dead simple. Let the model sink and soak the chemical over night, then you use old hard toothbrush to strip the paint. You might need to redo the process depending on how much primer and paint layers you had applied.
    Tested on plastic models.
    Canas likes this.
