AoS Double quicksilver potion question
Discussion in 'Rules Help' started by Lachlin, Feb 20, 2017.
  1. Lachlin
    Lachlin Well-Known Member
    Just want to make sure I did this right. I had and old one and a scar vet both on carnesaurs both with the potion. My skaven opponent charged the oldone with his giant rat demon thing.. The scar vet was 2 inches from the rat demon thing at the end of the charge move. I declared i was using both quicksilver potions. I piled in with the scar vet, and both carnesaurs proceeded to krump the rat demon thing, killing it before it ever got to strike. My question is, was the pile in move from the scar vet legal?
  2. Aginor
    If a unit is within 3" of an enemy one when the combat phase starts it can pile up, up to three inches.
    So I don't see why that would be a problem.
    What I wonder though: Is it OK to use both potions in one round?
    And based on that (sorry for slight derailing): If you opponent had had a QS potion as well, who would have gotten the first move? The last one who says "I use it"?
    Bowser and Lachlin like this.
  3. Crowsfoot
    What is the exact wording of the QS potion artefact?
    Lachlin likes this.
  4. Aginor
    It says:
    "You can use the potion once per battle at the start of a combat phase. This model attacks in the combat phase before any other models, and before the player whose turn is taking place picks a unit to attack with"
    Bowser, Lachlin and Crowsfoot like this.
  5. Crowsfoot
    I would say you go first then as it says "and before the player whose turn is taking place picks a unit to attack with" no mention about them having QS
  6. Seraphage
    Seraphage Well-Known Member
    Yes you piled in correctly and you had the right to use both. I have asked a similar question about both opponents using their quicksilver potion and as far as I know there still isn't an official answer. Common houserule is to roll a dice and the highest one wins. Others have used them "simultaneously". You can work it out with your opponent hopefully :D
  7. scubrat
    scubrat Well-Known Member
    My mate Rob who presents Warhammer TV sees a lot of tournament matches and it's totally legal to use both potions in one turn.
    Aginor, Seraphage, Crowsfoot and 2 others like this.
  8. Lachlin
    We do the dice roll off if both players have a QS potion. Thanks for the replies!
  9. Bowser
    The roll off is the most common, but yes using both in one round is perfectly legal.
    Aginor, Lachlin and Crowsfoot like this.
  10. Layken
    Layken New Member
    Q: What happens if two abilities affect the same dice roll? For
    example, if Screamers of Tzeentch – which near any Daemon
    Heroes of Tzeentch treat all enemy hit rolls of 6 as hit rolls
    of 1 – were hit by a unit for which a hit roll of 6 produces a
    mortal wound.
    A: Always use abilities that modify dice rolls before
    applying any abilities that are triggered by the
    (modified) dice roll in question. For example, a
    Retributor affected by an enemy ability that applied a -1
    modifier to the Retributor’s hit rolls would have to apply
    the modifier before seeing whether it was able to use its
    Blast to Ashes ability. If there is still a conflict, the player
    whose turn is taking place applies their abilities first –
    see ‘When to Use Abilities’ in the Hints & Tips section
    for warscrolls.
    m0gstar, Bowser and Seraphage like this.
