Help Need help.
Discussion in 'Painting and Converting' started by skinkyone, May 28, 2019.
  1. skinkyone
    skinkyone Active Member
    Currently struggling with a paint scheme for my dread, i started with the idea of a green blue scheme like a iguana however as you can see the more natural green doesn't offset very well with the bright blue.
    The blue needs to stay as its painted over the green and i dont have the energy to strip the model but has anyone got suggestions for what colour to put with it/ any suggestions on how to get the colours to work together.
  2. Crowsfoot
    Where they meet you could use another colour in a pattern to break up the line, maybe adding stripes.
    Yellow maybe or red?
    Another way is too glaze where they meet, a blue glaze onto the green to soften the line, it would take quite a few coats but let it dry completely between coats.
    skinkyone and LizardWizard like this.
  3. skinkyone
    Took the plunge and changed to full blue (thank god for airbrush thinner when painting)
    Still need a second colour, what about purple?
  4. Explodingzeb
    I think a mottled purple over some of the blue would work.
  5. skinkyone
    So the entire model will be this blue shortly.
    However it looks drybrushed if that makes sense.
    Would a lightblue glaze help this?
  6. Aginor
    I actually like how it looks, at least on the picture.
    But yeah, a light blue glaze and then some white highlights on the most raised parts would look pretty cool I think.
  7. Darklorddan
    Darklorddan Member
    I might go with a lighter, whitish shade on the underside of the model (belly, throat, bottom of tail etc). It tends to go that way in nature, and it will break up the blue a bit.
  8. Xicohtencatl
    Xicohtencatl Member
    COOL model dude! i do like it, its gonna be awesome when finished!
    when Im finished with drybrush I use some wash (color depends on you) to merge the colors of highlights and recesses. I even do many back and forth actions of drybrushing and washes depending on the model... and at the end i tend to put the model under cold running water ( shower or in sink) the drybrush leaves dried pieces of pigment where i dont want them (for instance in red mouth i had white dots because dry brushing teeth) my dinos: http://www.lustria-online.com/threads/scaly-cohorts-from-ziggy_paint-the-beginnings.23117/
  9. Oh_Man
    Oh_Man Well-Known Member
    My thoughts and prayers are with you during this dark time.
    Xicohtencatl likes this.
