AoS NEW ON AOS BUILDING A 1K ARMY
Discussion in 'Seraphon Army Lists' started by Toxitrixx, Mar 20, 2020.
  1. Toxitrixx
    Toxitrixx Member
    hi everyone ,
    im new on this forum and on Age of sigmar ! i have played 40K few years ago and now im starting
    a seraphon army.
    I want to build an coalesced thunder lizard army and i Wonder if you guys could give me some advices and tips , thanks a lot !
    leader :
    -oracle on troglodon 260 points
    -skink starpriest 120 points
    units :
    20 saurus warriors 180 points
    behemoths:
    -bastiladon 220 points
    -bastiladon 220 points total : 1000 points
    i already have the 20 saurus warrior , the starpriest and the oracle on troglodon (i find him pretty cool with the bonus on cast and the disspell without range and he has the bonus from thunder lizard too)
    what should i change in the list ?
    forgive me if i made mistakes i am really new on age of sigmar ahah
    Thanks for your time
    Imrahil, Womboski and LizardWizard like this.
  2. LizardWizard
    Welcome to Lustria!
    I would consider taking a Carnorsaur as the leader for Thunder Lizards over taking the Trog. The Carnosaur gains a lot more out of the command trait. Running Thunderquaker is also worth considered if you plan to bring most of the required models already. This is to gain the extra artefact slot for taking Aetherquartz Brooch from Malign Socrcery. Atherquartz Brooch lets you roll a dice each time you spend a command point and gain a new command point on a 5+. Which is massive since you will be spending multiple cp every shooting phase with Thunder Lizards.
    Lizerd, Womboski and Toxitrixx like this.
  3. Toxitrixx
    Toxitrixx Member
    first thank you for your quick answer !
    Now i understand why carnosaur is better than troglodon.
    So i change troglodon by an oldblood on carnosaur but it s not a problem to have only the starpriest as a sorcer ?
  4. LizardWizard
    I like to have both a Starseer and Starpriest in most of my list. Just having the one isn't too bad though.
    Imrahil and Toxitrixx like this.
  5. Toxitrixx
    Toxitrixx Member
    okay thanks a lot !
    one last question , 2 bastiladon is good or should i change one for a engine of god or a stegadon or an other creature ?
  6. LizardWizard
    I think Bastiladon is better than any of the Steggadon versions. And it is cheaper.
    Toxitrixx and Imrahil like this.
  7. Toxitrixx
    Toxitrixx Member
    Hi Again
    Today i played with a friend in a 500points battle and i found that saurus warrior and knight were pretty strong with an oldblood in koatl's claw so i dont know anymore If i should run Thunder lizard for a 1K army or not. What do you think guys, which one is more fun and competitiv between thunder lizard and koatls claw in 1k army ?
    Thanks for your answer and have a good evening
  8. LizardWizard
    I think Thunder Lizards is by far our weakest subfaction. I would steer towards Koatl's Claw for Coalesced armies.
  9. Toxitrixx
    Toxitrixx Member
    Okay i see , i will make a list with an oldblood , some starpriest and priest or starseer for the buff and maybe an astrolith , and then a lot of warrior and knight
    Thanks a lot !
  10. Womboski
    Womboski Well-Known Member
    Thunderlizard works around big monsters which is easier to work with in 2k games so Koatls claw is probably the way to go.
    Imo Thunderlizard is for monster heavy skink armies that don't want to be starborn or for specific ideas like double shooting bastilidons, buffed up stegadon chief or Sunclaw oldblood on carno buffed up(you trade a +1 to hit buff and extra CPs for extra mount attacks and wounds)
    If you want to go Saurus and coalesced Koatls claw is the go to.
    LizardWizard and Toxitrixx like this.
  11. Toxitrixx
    Toxitrixx Member
    Okay thanks for tour answer !
  12. Toxitrixx
    Toxitrixx Member
    Good evening ,
    I come back one more time with my final list(i hope ahah)
    Coalsced , koatl's claw
    Leaders :
    -oldblood on carnosaur 250 points
    -skink starseer 140 points
    Battleline :
    - x30 saurus warrior 270 points
    - x10 saurus knight 200 points
    Total : 980 points
    The plan is to buffed and support the saurus with the starseer and the starpriest and to generating a lot of CP. With all this support i think the warriors and knight can be very strong.What should i change in this list guys ?
    Thanks !
  13. LizardWizard
    I like it!
  14. Toxitrixx
    Toxitrixx Member
    Okay let's go on then !
    Thanks guys for all your advices !
    LizardWizard and Womboski like this.
  15. Toxitrixx
    Toxitrixx Member
    Hi again ,
    I have my first matches with this army in few months and i want to make some changes. Here the new list :
    Leaders :
    Units :
    - x40 saurus warrior 320 points
    - x5 saurus knight 100 points
    Endless Spell :
    -Bound Geminids of Uhl-Gysh 70 points
    Total : 1000 points
    The objectiv is always to buff the warrior and Knights with starseer , oldblood and starpriest and to generate a lot of CP with this 3 leaders but i trade 5 knights for 10 warrior and 1 endless spell . Is this trade worth ? should i change something else ? and i dont know which endless spell should i choose for 70 points but this one seems good to me.
    Thanks for your time and your answers !
  16. LizardWizard
    I like your list.
    I think Saurus Knights and Geminids are the right call. The only change toward optimization that I would considered is dropping the Carnosaur to instead bring a Sunblood and Scar-Veteran on Coldone. They will do more to buff up the block of Warriors. Carnosaurs are awesome though!
    Toxitrixx likes this.
  17. Toxitrixx
    Toxitrixx Member
    Okay , i though about dropping the carnosaur but i though he can be good vs alone target like sorcer or target with a lot of hp , i will try it and see .
    Again , thanks a lot for your advices.
  18. LizardWizard
    The Oldblood Carno has the potential to tear up some hordes. I just think you will get more damage by adding +1 to wound rolls and exploding 6's to hit to your Saurus Warriors. It comes at the cost of being all in on the Saurus Warriors though. And depending on what you are fighting the Warriors might just be overkill with the double buffs.
  19. Toxitrixx
    Toxitrixx Member
    yeah i see maybe this double buffs + buff of starpriest is too much for one unit of 40 saurus , should i play 2 units of 20 saurus instead ?
  20. LizardWizard
    It would let you bring clubs, thus gaining rend 1. It will also let you buff one unit into a glass hammer, and then buff the next into a glass hammer later in the game. I haven't double checked the math, but you might be over 1k if you split.
