Help Question about water bases
Discussion in 'Painting and Converting' started by Sealterbloind, Apr 21, 2016.
  1. Sealterbloind
    Sealterbloind Active Member
    Martin_Martinić, Warden and Zenard like this.
  2. Zenard
    Zenard Active Member
    Am curious as well, looks really good!
  3. Jorgik
    Jorgik Well-Known Member
    I think all of the products are suitable for both, it´s just that as you have a maximum depth which to pour (usually about 2-3 mm max), for larger and deeper water features you will have to pour more than one layer. The only difference between brands is the depth you can pour (which at the end is basically the time it takes you to fill all you want covered). But I am not specialist on this and of course this is only what I think, so of course I could be wrong. Hope it helps ;)
  4. Warden
    Thank you for that link! Some amazing stuff on there. Watery-bases can look amazing when they are done well, I hope yours turn out great! Good luck on your project
  5. Toltecatl
    Toltecatl Well-Known Member
    Ill be trying stuff with prince august still water in a few weeks, ill let you know how it turns out if you went. Good luck :)
