AoS Saurus knights based dracothion’s tail
Discussion in 'Seraphon Army Lists' started by Lizerd, Jan 15, 2020.
  1. Lizerd
    Lizerd Well-Known Member
    I was wondering if this list which put more focus onto saurus knights and getting as many attacks in has potential. The pros would be more batteline that packs a decent punch, with the noted con of dropping Ripperdactyls
    Allegiance: Seraphon
    Mortal Realm: Ulgu
    Leaders
    Slann Starmaster (260)
    - General
    - Trait: Great Rememberer
    - Spell: Stellar Tempest
    Saurus Oldblood on Carnosaur (240)
    - Artefact: Doppelganger Cloak
    Saurus Scar-Veteran on Carnosaur (240)
    - War Spear
    - Artefact: Sword of Judgement
    Saurus Astrolith Bearer (160)
    Skink Starpriest (80)
    - Spell: Meteoric Convocation
    Battleline
    10 x Saurus Knights (160)
    - Lances
    - Lances
    - Lances
    Units
    3 x Razordons (120)
    1 x Razordons (50)
    Battalions
    Dracothion's Tail (80)
    Firelance Starhost (150)
    Endless Spells / Terrain / CPs
    Balewind Vortex (40)
    Total: 2000 / 2000
    Extra Command Points: 2
    Allies: 0 / 400
    Wounds: 120
  2. Lizerd
    @LizardWizard sorry to bother you oh wise and powerful one... but could this list work and what is your insight on it?
  3. Erta Wanderer
    are you taking it to turnies or is it just for fun?
  4. Lizerd
    For fun, but it is somewhat competitive
    Erta Wanderer likes this.
  5. Erta Wanderer
    you will do fine in for fun games as long as the opponent doesn't know how Seraphon play. but a competitive player will tear it in half
  6. LizardWizard
    I think you should fit in Cogs. Changing those 9" charges into 7" is huge. Otherwise I like this list. Great Artefact selection! You have the option pump CP into the Knights via the ScV CO or to pump them into the OBCarno. DT is great at board control. It isn't glamorous, but you can lock down a lot of the enemy's movement with the list.
    Erta Wanderer and Lizerd like this.
  7. Lizerd
    I’m interested in how it will stand, as offensively it may have potential, with a scar vet and skink starpriest could be fun
  8. Erta Wanderer
    when i build 2k competitive lists i try to have 3 solid threats that my opponent can deal with and a average of 40-50 damage a turn. this list is close on the later but only has 2 ish threats being the knight cloud and sort of the razors. for fun you will run around the field and smash people
  9. Lizerd
    Cogs looks cool, what would you recommend I drop?
  10. LizardWizard
    I would say either the ScV on Co or a unit of Knights down to 5. I like dropping 5 Knights the most. You just don't have to have the ScV Co since have an ScV Carno for battalion purposes. And you want to have a unit of Knights on the table to begin with. I am guessing your Carnos, 10 Knights, and the ScV Co are what you plan to put in the Heavens.
    Lizerd likes this.
  11. Lizerd
    How did you know?! I could see dropping 5 knights making the most sense as a unit of 5 can still put out 21 attacks. I also could drop the scar vet on Carnosaur which would allow me to take Ripperdactyls and the cogs, ultimately the decision comes down to which I can have pump out more damage. As for units in the heavens I was thinking along your lines with the carnosaur as I have had really good experiences with deep striking them.
    edit; what am I thinking, two carnosaurs are clearly better than one. That mere train of thought of not taking two carnosaurs makes me wonder if I have severe brain damage
  12. Antisense
    Antisense New Member
    I love this list. I'm doing something similar as I start off on Seraphon. But going to lean a bit more on getting those blazing lances 6s by using a Sunblood to get tilt the odds a bit.
  13. Lizerd
    Be careful with this list, it is somewhat fun to run in a friendly setting but it doesn’t fare well against alpha strike lists. It does however match up decently against horde based armies due to the sheer volume of attacks
  14. Antisense
    I've gotten absolutely tabled by a Living Cities list and a FEC list so far, both at 1k points. As I learn, I'll stop getting outright tabled, but still having fun BSing with folks. I also play the Scar-Vet on Carno's exploding 6s command ability as endlessly proccing as long as you continue to roll sixes, so that was a blast on my Sunblood! ;P
    But yeah, the level of murder in the combat phase that this game has gone to totally leaves any Saurus shenanigans in the dust, i have to say. I'm just trying to make the best use of defensive buffs and Bravery manipulation to start to turn the tide in the attrition battle.
