Help Alternative Slann models advice? (King Sgrakkor)
Discussion in 'Painting and Converting' started by Braininthejar, Feb 14, 2022.
  1. Braininthejar
    Braininthejar Active Member
    I am thinking of making my second slann, and since I wanted him to look different, I have been considering King Sgrakkor from Artisan Guild.
    The Model seems cool. The only problem I have is the scale - from the description, he seems a good deal bigger than a normal slann.
    Has anyone here tried this model and could share his experience?
    Just A Skink likes this.
  2. Just A Skink
    Yes, I use that model as my Slann. I bought it from a merchant on Etsy. You're right, the "standard sized" version of the model is bigger and on a 75mm (approx.) base, about the size as Kroak's base. I asked the printer to scale it down the mini to a 50mm base and the mini seems the right size (although the base ended up closer to 55mm). However, I don't have an GW Slann to compare.
    Check out my photos of the model. I hope they give you a good idea of the size.
    https://www.lustria-online.com/threads/watching-paint-dry-blog.22156/page-2
