AoS Bound Aethervoid Pendulum
Discussion in 'Seraphon Tactics' started by Just A Skink, Apr 3, 2020.
  1. Just A Skink
    I'm kind of an idiot, so can someone help me with the Aethervoid Pendulum Endless Spell?
    Why is the bound version included so often and how does it get used? Doesn't it just go in one direction only?
    Do you just dispel it and recast?
    Thanks!
  2. Erta Wanderer
    people like it because it's got a big base so it's good at blocking and it does the most damage of standered endless spells at a d6 to all units in range or that it passed over.
    yes it only goes in one direction but it doesn't have to move and so if you can get it into a clump of units it can do good work.
    i don't personally talk it but it does have a lot of uses
  3. Just A Skink
    Ah. I haven't really read the spell closely, so I assumed you HAD to move it every round. That's interesting.
  4. Erta Wanderer
    well even if you do have to move it you can just nudge it a half mm and your good
  5. LizardWizard
    You can choose to move 0". Which is important to know from a rules perspective in general.
    Ecozh, Canas, IggyStarhost and 2 others like this.
  6. Alladin the Paladin
    Not sure how useful the bound version of this one is as it’s really a one turn spell most cases. You use it, deal d6 damage, and then your opponent gets all his units out of the path of it.
    I guess you can position it such that an opponent has to get in its path to claim an objective, and play chicken with him
    IggyStarhost and LizardWizard like this.
  7. LizardWizard
    I mean, if you cast it at the bottom of the turn you get to use it twice before they can react.
    RandomTsar and Just A Skink like this.
  8. IggyStarhost
    you mean if you’re going second in the battleround right? The ‘plus’ side which the unbound version has, is you cast it while going second in the battle round and lose the roll of for the next battle round. Is that your opponent need to think hard in giving you a double turn or getting double Aethervoid on a important unit(s), like morathi or so. But if you do have the points bounds seems the way to go.
    Although, I’m still baffled about the finals of adepticon 2019. Where sam took the game by ‘forgetting’ to charge his rippers. Forcing the opponent to either take the first turn or get rippers in his face. It was the battleplan where going second gave 3 points instead or 1 per battleround
  9. LizardWizard
    You get to move and control all your bound endless spells. Endless spells move and trigger at the start of the battle round before either player has a turn. So, if you cast Bound pendulum on a turn in which you went second, then you will be able to activate it twice before you opponents gets their movement phase.
    Canas likes this.
  10. Alladin the Paladin
    This makes sense. I have never played endless spells and though I know the mechanic it’s hard to visualize. 10 pts for an extra d6 MWs is worth it for sure then.
  11. erians
    erians Active Member
    It can still do 2D6 without being bound. You cast it when you're going 2nd, then move it within 1" of a unit. Then regardless who takes the first turn of the next battleround it will it remain stationary and deal damage, or move through the unit and deal damage.
    The advantage of having it bound is that you block stuff by placing it in the way then never moving it (and your opponent cant move it either obviously since its bound). Tzeentch before the new book used to take like 5-8 endless spells and basically box in large threats with endless spells making them completely immobile.
  12. Grotpunter
    Grotpunter Well-Known Member
    But if it isnt bound, your opponent can just choose not to move it at all? The warscroll says it deals damage to models it has passed across or within 1” at the end of its move. Never heard of a “at the end of an Endless spell movement phase”, so I would assume it only deals damage if it actually moved.
  13. LizardWizard
    Moving "0" is still movement. What matters is that the spell is selected to by a player.
    Having the bound version will let you have greater flexibility on how the spell approaches the desired unit/s though. In a lot of cases if your opponent is able to move it 8" they will be able to place the spell more than 1" away from small units or support heroes.
    It also allows the spell to act as a wall.
