AoS Engine of the Gods
Discussion in 'Seraphon Discussion' started by xoid, Mar 30, 2020.
  1. xoid
    xoid Well-Known Member
    Just want to check, my understanding is that even though it now has a skink priest on it's back it doesn't pick up the skink priest keyword as the FAQ was written, correct?
  2. Davema
    Davema Well-Known Member
    I thought that was a strange update - what was the point of it?
    Slikus Vaw and Erta Wanderer like this.
  3. Nart
    Nart Well-Known Member
    To have a rider and a mount. Priest does nothing, actually.
    Canas, Just A Skink and Davema like this.
  4. ILKAIN
    ILKAIN Well-Known Member
    the priest is now the hero, they did it to stop putting artifacts on the stegadons weapons. it was expected.
    Canas, Imrahil, Nart and 1 other person like this.
  5. Just A Skink
    "BAH!" I know it might have been expected, but still "BAH!"
  6. Satoabe
    Satoabe Member
    But since there is a priest...can Kroak cast a spell through the EotG?
  7. Nart
    It didn't receive priest keyword or anything, unfortunately. Skink Priest is just a name of a hero, riding Stegadon and Arcane Vassal is bound to keyword, IIRC.
  8. Putzfrau
    Only works on skink wizards and oracles.
  9. Batch
    Batch Active Member
    It does seem like at that price point, and the obvious EoTG nerf that it could have had the Priest keyword, give it a prayer even if making it a wizard is too much.
    Cuetzpal Pilli likes this.
  10. ILKAIN
    GW would have to like us for that to happen.
    Canas, Cuetzpal Pilli and Slikus Vaw like this.
  11. Imrahil
    So this will mean skink priest on foot and the skink hero on top of it.
  12. Mees
    Mees Member
    Then I guess an EotG is still not able to get the Master of Star Rituals trait in a Thunder Lizard army since it has a monster mount? Too bad :/
  13. Alladin the Paladin
    I think it can? The stipulation is that it can’t be a wizard if you want the free CP ability from the priest.... someone correct me if I am wrong though
    Canas likes this.
  14. Nart
    You have to take Prime Warbeast for Mounted warlord in Thunderquake Templehost. If you want MoSR for free CA, you'll have to give it to Skink Priest - there's no other options.
  15. Alladin the Paladin
    Ahh yes, I am a dummy.
  16. Slikus Vaw
    Slikus Vaw Active Member
    so in all technicality you can bring 2 EotGs nd activate them 3 times total with the thunder lizard command ability
  17. Nart
    Yes.
  18. Shadowkaos
    Shadowkaos New Member
    It says in the EOTG rules "At the start of the shooting phase, you can make 1 cosmic engine roll for 1 model with this ability."
    It does not say, "An EOTG can make 1 cosmic engine roll."
    The "For 1 model with this ability" denotes that only 1 of the models can make that roll.
    GW doesn't want someone bringing 5 of these and creating 2 -6 units of saurus every turn.
    Canas likes this.
  19. Slikus Vaw
    I know, you would be using the EotG ability once normally without a command point nd then twice with the command ability from the thunderlizerds at the end of your shooting phase but point wise it's not really worth it.
    Canas likes this.
  20. Shadowkaos
    I think it is worth it with a slaan, When you tell your opponent it can potentially create 2 units of Saurus a turn they will put a lot of effort into getting it instead of your other threats and it typically if fired twice creates 2 units a game if protected, that makes a 260 point unit into a 180 point unit with a pocket 180 unit.
    Just A Skink and Canas like this.
