How do I assemble Lord Kroak?
Discussion in 'Painting and Converting' started by abcdeh, Feb 15, 2013.
  1. abcdeh
    abcdeh New Member
    Probably the same as a regular Slann, but how do I assemble Lord Kroak? I've got his throne all glued and assembled and he's all ready to go, but I don't know how I'm going to attach the little flying stem to the base! Do I need to put a hole in it? Should I put a blob of green stuff on it? Advice would be great :)
  2. n810
    I would ditch it and replace it with a nail or some other piece of metal,
    thise plastic rodds allways seem to break.
    If you realy want to use the plasti rod,
    either you mound it in the clear disk (if your kit came with it)
    you clue that to the rods and glue the whole thing to the base,
    and then glue the slan to the rod...
    (might want to use some green stuff here)
    I recomend doing this with the slann upside down,
    with the base proped up while it dryes.
    Ps. if you don't have the clear circle thingie, you have to drill a hole in the base.
