TOW Master Blaster-2000 pt
Discussion in 'Lizardmen Army Lists' started by sirkently, Feb 18, 2024.
  1. sirkently
    sirkently Member
    Here is a 2000 point list concentrating on magic missiles. Have 5 bound MM spells plus what the wizards end up with. The slann can pick another one for sure. Got a couple small bricks to help out. Could be interesting. Any thoughts?
    Characters
    Slann Mage-Priests: General, Battle Standard Bearer
    Transcendent Healing, Necromancy
    Lore Familiar, Ruby Ring of Ruin
    Wizard Level 2, Battle Magic
    Cube Of Darkness
    Ancient Stegadon: Engine of the Gods
    Core
    Saurus Warriors x16
    Thrusting Spear, Shieldwall
    Spawn Leader: Obsidian Lodestone, Standard Bearer
    Temple Guard x14
    Revered Guardian: Obsidian Lodestone, Musician, Standard Bearer: Skavenpelt Banner
    Special
    Bastiladon: Extra crew member
    Solar Engine
    Solar Engine
    Rare
    Ancient Stegadon
    Engine of the Gods
  2. Kalisto
    Kalisto Active Member
    Interesting list. But I should try to play some skirmish to use as screen or to scout. Removing lodestones and banner. May ask why necromancy to the Slann?
  3. sirkently
    sirkently Member
    Necromancy is for curse of years. Hope to reduce toughness for the saurus blocks.
  4. Kalisto
    Clear…
    Lodestones is quite useless since you have already a caster level 4 to dispel.
  5. Haemoglobin
    I've tried a similar list (fireball bound, 2x Bastiladon, Ancient Steg and High Magic) and it felt a bit underwhelming. Most opponents have a lvl 4 to dispel so you're not going to get a lot of turns where you can get them all off.
    Bastiladon missile is nice though when it goes off.
    Kalisto likes this.
  6. SimeonHash
    SimeonHash New Member
    Necromancy is nice IMO for Leadership spells ... (-2 Ld Hex , -1 Ld Vortex ) add to that Curse of the years (-1 Ws , -1M & -1 T) and very good MM 3d6 St2 no ArmSv you got probably best Lore if you go with a lot of "Terror" units ... Bastiladons are nice but casting at 9+ with Spell level 2 is closed to 50% chance of casting . So for me is the better solution invest points in Ancient Stegies with Engines
  7. Kalisto
    Yeah but Stegadon have a 15” range. And they can fail too cast too. Last but not least there are 100 points of difference. I don’t think one is better than another. They just have different purpose and rolls. Bastiladon is more defensive , try to avoid melee and block enemies to get a flank. Shooting in the while. Stegadon have a much more offensive and melee roll
