Help Need Help: Thunder Lizard Howdah help
Discussion in 'Personal Paint Logs' started by Sudsinabucket, Apr 7, 2020.
  1. Sudsinabucket
    Hey all! So ive decided its time to really put my foot to the pedal and finish the Thunder Lizard's howdah...I am however stuck. I cant decide how I want to do the icons that are not filled in, aside from the small orbs that go down the center of them, they will likely be ret armor.
    How would you color the icons? I want them to be identical aside from maybe the small snakes at the bottom, I am thinking of making them different species. The sides will be pure gold except the little triangles which will be red and blue like the central platform is.
    Any thoughts are very welcomed, encouraged and sought after!
    Thanks,
    Suds/Sinarai
    EFHILT 167, Captaniser and Imrahil like this.
  2. Egres
    Egres Well-Known Member
    It’s looking pretty good so far!!
    If the railing can pass as wood I would perhaps paint them brown and top off with gold that been said if no other Howrah in your fleet as wood it skip that lol
    EFHILT 167, Imrahil and Sudsinabucket like this.
  3. Sudsinabucket
    The only wood I have for a howdah is on my Stegadon conversion, however this being a Thunder Lizard I feel more gold is needed to, lorefully, keep the beast under control (though in my own fluff my faction is able to control Thunder Lizards due to raising them from birth and them imprinting on their Priest/Seer that raises them) as gold is a magic amplifyer
    Wood does look good on the other howdah however, so not a horrible idea, just not sure it works for what i'm going for here for the railings
  4. Imrahil
    Just to remind us of the colors on the middle Howdah you got already done:
    This might help.
    I am not a fan of to many different colors and sort of a color-theme.
    So I would go with some of the darker Red/Purple you got in this middle howdah already.
    Or even the starry bits.
    Sudsinabucket likes this.
  5. Sudsinabucket
    Good call on the photo, here is an even more updated one from last night with the very small side platforms added which have been painted gold. The small triangles will be red and blue like the others :)
    EFHILT 167 and Imrahil like this.
  6. Sudsinabucket
    Progress! After consulting with a few people decided to go this route:
    Top circle is Khorne Red
    Bottom Moon shape is Lilac, Xereus Purple and then Volupus Pink
    Central dots are Retribution
    Still undecided on the small snakes...
    EFHILT 167, Imrahil and Explodingzeb like this.
  7. Imrahil
    Very nice.
    For the snakes you could go either for same colors in a different pattern or different colors(maybe some Green and Blue)
    Somehow I think you can't go wrong there, it will look great anyway.
    EFHILT 167 and Sudsinabucket like this.
  8. Sudsinabucket
    I thought about green! I ended up however just reversing the colors of the middle howdah snakes, black base, red markings and yellow lines
    This is the most updated photo
  9. Imrahil
    Good call ;)
    Also I like the brighter Red circles at the top, to match the one in the middle howdah:artist:
    Great progress, Keep up the good work
  10. Sudsinabucket
    Looking to have them finished in the next couple of days, then to decide if I still want to add gold chains or not
  11. Sudsinabucket
    Considering putting the EOTG chair + Priest on her infront of the Astrolith Banner i was originally planning to use
  12. Imrahil
    That is a throne worthy of the Thunder Lizard :cool:
    What does it look like from the back?
  13. Sudsinabucket
    Unpainted atm
  14. Sudsinabucket
    Im planning to fill the openings of the wooden parts itself, the front im thinking of adding spear heads as forward shooting things
  15. Sudsinabucket
    Not about howdah colors but howdah related, need some opinions
    Trying to decide how to connect my Astrolith Banner/EOTG to my Thunder Lizard. Originally I was going to put it directly behind the throne (first picture) but now I am considering putting it above the throne (second picture). The reason I am starting to rethink my choice is due to that the Oracle piece on the banner itself gets blocked by the throne when directly behind it.
    What are your thoughts?
  16. Imrahil
    I see what you mean...
    The thing is, in my opinion, do you want it as a part of the throne or saperate?
    If you want to be a part of the throne, you could cut the sides of the throne and lower the Astrolith part
  17. Sudsinabucket
    Also this option of taking the back piece od the throne off
    Hmmm...not sure if I want it as a part or not...cant decide...
  18. Imrahil
    I like the last one a lot:cool:
    Maybe If you put a Skink in or in front of the throne it gives a better glimps of the end result.
  19. Sudsinabucket
    EFHILT 167 likes this.
  20. Imrahil
    Bit distracted by SpongeBob chasing the Thunder Lizard:D:D lol
    But i'd say perfect fit.
    (Ofcourse only you can decide, so no pressure ;))
