AoS Spatial Translocation and Soulscream Bridge
Discussion in 'Rules Help' started by LuckyKalle, Jun 21, 2023.
  1. LuckyKalle
    LuckyKalle New Member
    Hi everyone,
    when I´ve tested my first list with the new rules, this question comes around:
    Can you use the Souelscream Bridge with your Oracle in the movement phase after you have teleport him with the Spatial Location in your Herophase?
    The wording of Spatial Translocation is "you cannot move in the following movement phase".
    The Soulscream Bridge summed up says : at the start of the movement phase; remove 1 unit; set it up again.
    Is removing and setting up considered as a move?
    Or is "cannot move" different to "cannot make a (normal) move", so it doesn´t matter if removing and setting up is defined as a move, the modle just have to stay where it is?
    I hope you can clear it up for us,
    thank you
  2. Hapijoel
    Hapijoel New Member
    On the one hand, any movement is a Move, but ive been told that since the Soulscream Bridge removes models and puts the back down, it gets around this, so it does *not* coun't as a move. Thanks for bringing up as its got me interested in how to use this now!
