8th Ed. Tetto'Eko and priest deployment
Discussion in 'Lizardmen Tactics' started by Blastoize, Jan 17, 2024.
  1. Blastoize
    Blastoize Well-Known Member
    Hey fellas,
    in our upcoming grand battle (we've decided to try and run 5,5k points, which is about what we have available)
    I am rocking Tetto'Eko and 2 other priests (and Kroak and another slann for that matter xD).
    I want one priest to be solo with cloak of feathers, one will probably be running around with a unit of 10 skirmishers and then I am uncertain where to put Eko.
    I have only limited skink models available (and sadly saurus as well) and I am going with 2 skrox units (one is 4+ 32 (or 42) and the other one is 3+ 24 skinks) to try and fill as much of a core as possible (we are quite lenient about the percentage, as it is mainly a battle for fun and spectacle).
    Would you go with just a cohort bunker for Eko, skirmish or solo?
    Thanks for any suggestions .)
    B.
    - Q - likes this.
  2. Quinn
    Quinn New Member
    Tetto' Eko is super weak, so if he gets charged he will pretty much be killed instantly, and because of his great special rule that let's you re-roll 1's this cannot happen. Unless you are extremely sure he will not be targeted by a charge you should absolutely put him In bunker. Sorry if this is a late response, have you already played the game?
    - Q - likes this.
  3. - Q -
    I think you're right. Tetto'eko should be kept in a bunker as far away from combat as possible. Let the little Skink do his work from a safe distance.
