AoS DT teleporting thought
Discussion in 'Seraphon Tactics' started by Slikus Vaw, May 12, 2020.
  1. Slikus Vaw
    Slikus Vaw Active Member
    So I was thinking in DT we can have units start off the battlefield and also we can teleport. So I was wondering if say kroak is near mid field then DT AoC(appear on command) some units in then teleport kroak somewhere then DT AoC in some more units on the same end of movement phase? This could be real useful for one of my lists. I don't see anything that states that I cannot. The only restriction is at the end of movement for both.
  2. Canas
    since both happen at the end I guess it's acceptable.
    LizardWizard, Slikus Vaw and Imrahil like this.
  3. Slikus Vaw
    So think maybe the determining factor is how DT AoC is activated, if it's activated for every single unit or if its just a once per turn army wide ability
  4. Canas
    Abilities can be triggered "simultaniously" in which case the player who's turn it is gets to decide which goes first. So unless DT is 1 ability for the entire army at once you should be fine.
    Nart and Slikus Vaw like this.
  5. LizardWizard
    You absolutely can split drop your AoC on either side of LoSaT.
  6. Slikus Vaw
    Sweet muahahaha
    Imrahil and LizardWizard like this.
  7. ILKAIN
    ILKAIN Well-Known Member
    I thought the player controlling the abilities choose the order of those abilities, with the person whos turn it was going first if both players had simultaneous triggers.
    the way you say this makes it seem like I could choose the order of triggers for my opponent if they trigger on my turn.
  8. Canas
    Technicaly yea, I think so. It's supposed to be the person who's turn it is, this is mainly to decide who goes first when both players trigger something simultaniously.
