AoS Help a Lustrian in distress?
Discussion in 'Seraphon Discussion' started by Xuil, Aug 3, 2019.
  1. Xuil
    Xuil Well-Known Member
    So I just dropped my Carnosaur...
    Somehow the only irreparable damage is to the top of his head, as the parts are missing.
    I’m faced with the proposition of painting him as sorely wounded (costing my old blood some dignity) OR, I thought I would check if anyone has a spare bit kicking around?
    Thanks to anyone who’s able to have a rummage!
    The real kicker is that this happened just weeks after getting rid of my bits box!
  2. Serabelle
    Serabelle New Member
    Are you located in the US by chance?
  3. Lizerd
    Lizerd Well-Known Member
    That sucks, but it’s not out of the ordinary. Your plan to do a bad wound sounds pretty cool if you used some green stuff to work it out. You could also just repair it with green stuff (this is really only doable with the scar veteran) and depending on damage that could work. However depending on damage you may just need to replace it entirely with a new spare head.
    Mind if we see the damage?
  4. Erta Wanderer
    I have repair face plates where do you need them?
  5. Xuil
    Sorry, I should have noted that I’m UK-based! But thank you so much for looking, even if that’s an issue.
  6. Xuil
    UK, Hampshire :( But thank you anyway.
  7. Xuil
    Unfortunately it pinged off to who knows where! I’ve scoured the whole room without any luck, otherwise repair is my default.
    I don’t think a wound there would work as well as, say, our Sunblood? With that bit missing, his head just looks even more disproportionately small. :(
  8. Erta Wanderer
    your kit should have 2 head plates if that does not work ebay might have bits for sail and failing that it's only 1.30 to send a letter your way i can manage that
  9. Xuil
    Crisis averted! Another local seraphon player has found his spare.:D
    Thanks to everyone for the suggestions and Erta Wanderer for the offer.
    I first thought to ask around here because I already knew what a fantastic community this is.
    Killer Angel, Aginor, Lizerd and 2 others like this.
  10. Erta Wanderer
    we do what we can im glad it worked out for you.
