AoS New player
Discussion in 'Seraphon Army Lists' started by Tresaks, Jun 15, 2019.
  1. Tresaks
    Tresaks New Member
    I'm going to attend a 1750 points tournament next weekend.
    Currently i have put together this list.
    ++ *Old* *Pitched Battle (2,000)* (Order - Seraphon) [1,740pts] ++
    + Leader +
    Engine of the Gods [220pts]
    Saurus Astrolith Bearer [160pts]
    Saurus Oldblood on Carnosaur [260pts]
    Skink Priest [80pts]: Priestly Trappings
    Slann Starmaster [260pts]
    + Artillery +
    Salamanders [120pts]: 3x Salamander
    + Battleline +
    Saurus Warriors [200pts]: 2x 10 Saurus Warriors, Celestite Spear, Stardrake Icon, Wardrum
    Skinks [120pts]: 2x 10 Skinks, Boltspitters and Moonstone Clubs
    Skinks [60pts]: 10 Skinks, Boltspitters and Moonstone Clubs
    + Other +
    Skink Handlers [80pts]: 2x 3 Skink Handlers
    Terradon Riders [120pts]: 3 Terradon Riders, Starstrike Javelin
    + Allegiance +
    Allegiance
    . Allegiance: Seraphon
    ++ Total: 1740 points.
    I just went with things i thought would work well. And i hope to get off a descent amount of summons to put my enemy of his gameplan. Thoughts?
    Erta Wanderer likes this.
  2. Erta Wanderer
    i would combine the 20 and 10 skinks you only need 3 battle lines and the +1 to hit would help what else do you have acsess to?
  3. Tresaks
    Tresaks New Member
    20 Temple guard
    2 stegadons/eotg
    troglodon/Carnosaur
    skink chief
    20 saurus on cold ones
    going to order bastilladon, and a couple of razordon. but i dont get that in time for the tournament
  4. Klap
    Klap Member
    Will the tournament be using the points from the new generals handbook? That’s is out next weekend.
    If so there are things in this list that have had points changed and you may have to do a little tweaking.
  5. Erta Wanderer
    you could run a thunder quake with what you have hear it would do a lot with helping out you salamanders hitting things they can do terrrable things with rerolls on hits and wounds
  6. Tresaks
    Tresaks New Member
    @Klap i dont think so.
    @Erta Wanderer will have to read to on that. still waiting for mye battletome tho.
  7. Erta Wanderer
    a thunder quake is ether a EotG or a trogg (most run EotG) 2 stegadons or bastiladons any mix of and eather Kroxagar, razordons and handlers, or salamanders and handlers. costs 120 points and gives the following benefits
    Celestial Surge The great beasts of the Seraphon are almost invincible when they march forth as a pack, even more so when in the presence of the Starmaster that created them. In your hero phase, each model from the Thunderquake Starhost heals a wound. Models from a Thunderquake Starhost that are within 10" of a SLANN heal D3 wounds instead.
    The Creator's Will The Engine of the Gods or Troglodon, and any units from the Thunderquake Starhost within 8", are guided by the will of their creator. At the start of your charge phase, you can declare that all of those units will be swift until your next charge phase, in which case you can re-roll charge rolls for those units and hit rolls for attacks made by those units. You can instead declare that all those units will be savage until your next charge phase, in which case you can re-roll wound rolls for attacks made by those units and save rolls for attacks that target those units.
  8. Tresaks
    Tresaks New Member
    oh! looks solid, think i watched a batrep from mwg, where Steve used tq
  9. Erta Wanderer
    it's one of our best keep the astrolith berrer close and they do horable amounts of damage
  10. Tresaks
    Tresaks New Member
    thanks for the tip. Will take a closet look into that :)
