AoS Slann Shenanigans
Discussion in 'Seraphon Army Lists' started by Naits One, Jul 21, 2019.
  1. Naits One
    Naits One New Member
    Hey Guys,
    This is my first post and I want to have some opinions on this list
    Leaders:
    Kroak 430p
    Slann, General, 260p incandescent retrices, great rememberer
    Astrolith Bearer 160p
    Saurus Eternity Warden 140p
    Skink Starpriest 80p
    Oldblood on Carno 240p
    Battleline:
    10x Saurus Guard
    10x Saurus Guard
    5x Saurus Guard
    400 p
    Behemoth:
    Troglodon 140p
    Battalion:
    Eternal Starhost 150p
    The idea behind this list is to summon as much mobile stuff as possible and park the Slanns behind a guard screen to cast for a lot of mortal wounds, using the troglodon as channel for range.
    LizardWizard and Ixt like this.
  2. Ixt
    Ixt Well-Known Member
    I love the idea of using 2 Slann to churn out CCP. Thanks, OP, never thought of that!
    If summoning is the goal, would it be worthwhile points-wise to downgrade Kroak to a normal Slann?
    edit: whoops! didn't knowit's only the general.
  3. Audvin
    Audvin Active Member
    Only the general generates CCP?
    Ixt, Slikus Vaw and LizardWizard like this.
  4. LizardWizard
    Yep, Kroak would just be mortal wound spam.
  5. Aginor
    Yeah. Still can work, with the Slann doing the summoning and Kroak nuking.
    I only tried it once though and rolled badly, so I am not sure how reliable it is.
    Welcome to Lustria!
  6. Killer Angel
    Welcome to lustria!
    some problems with this list:
    1 - "to summon as much as possible" means your slann won't be casting too much. So you don't need the Troglodon. Save those points and pick a Vortex plus something else.
    2 - your slann will cast 1-2 spells at most, using our lore to deal MWs. the starpriest will serve as vassal as well if there's need
    3 - I suppose you are planning to deal MW basically with double LoSaT Kroak, am i right?
    4 - eternal starhost in not a strong battalion… if you plan to keep it as Slann protection, you are wasting points. you could simply form a barrier with 10 knights.
  7. LizardWizard
    Here is how I run double Slann:
    Allegiance: Seraphon
    - Mortal Realm: Ulgu
    LEADERS:
    Slann Starmaster
    (260)
    - General
    - Command Trait : Great Rememberer
    - Artefact : Miasmatic Blade
    Lord Kroak (430)
    Saurus Astrolith Bearer (160)
    - Artefact : Light of Dracothion
    - Artefact : Betrayer's Crown
    Skink Starpriest (80)
    Knight-Incantor (140)
    - Allies
    UNITS:
    5 x Saurus Knights (80)
    -Lances
    - Lances
    - Lance
    3 x Razordons (120)
    BATTALIONS:
    Firelance Starhost
    (150)
    Dracothion's Tail (80)
    ENDLESS SPELLS / TERRAIN:
    Balewind Vortex
    (40)
    Chronomantic Cogs (80)
    Everblaze Comet (100)
    TOTAL: 1980/2000
    EXTRA COMMAND POINTS: 2
    WOUNDS: 87
    Units in the Heavens:
    • Lord Kroak
    • Saurus Astrolith Bearer
    • Saurus Scar-Veteran on Coldone
    • One 5x Saurus Knights
    • One 3x Razordons
    The goal of the list is to spam mortal wounds and kill enemy support heroes with Kroak and the Everblaze Comet while thinning hordes with Betrayer's Crown and spells from the new Seraphon Lore.
    This is a two drop list and should allow for the army to dictate first turn. Generally it will be best to take the first turn when the most targets are grouped for both the Everblaze Comet and Kroak's Spells. Once the Slann Starmast is on BwV it should have range to use Stellar Tempest on a horde unit.
    Quick Guide:
    • Drop Lord Kroak and the Saurus Astrolith Bearer in range of enemy units.
    • Unload Kroak's Mortal wounds.
    • LoSaT both Kroak and AB to Safety.
    • Deploy the ScV on CO near an enemy horde that is out of range of your Slann's spells.
      • This is to use Betrayer's Crown in the combat phase.
      • Deploy the Saurus Knights near the Co for support.
    • Cast Everblaze Commet.
    • Cast Cogs from Skink Starpriest near Slann.
    • Cast BwV for Slann.
    Slikus Vaw and Aginor like this.
  8. Slikus Vaw
    Slikus Vaw Active Member
    knights are 80 points haha
  9. LizardWizard
    right, wrote this list with the old app. pretty sure the total is accurate though. Good catch.
  10. Pallys
    Pallys New Member
    Hi, I'm new to seraphon and I was wondering how you get the dracothion battalion with only one other battalion? One of the requirements says 4 battalions from the list of sunclaw, firelance, shadowstrike, and eternal.
  11. Slikus Vaw
    It ses 0-4 other battalions
  12. Pallys
    Pallys New Member
  13. Pallys
    Pallys New Member
    My book seems to be borked or something cause it says 4 is needed, but I double checked on a gh19 review video on YouTube and it definitely says 0-4. Thanks for the info.
  14. Killer Angel
    Ouch.
    I fear so... it's the firelance starhost and 0-4 other battalions.
    That's why you gain command points on a 2+ if you pick the max number of battalions
  15. Pallys
    Pallys New Member
    Yeah, I guess I got a misprint or something, thanks for the info!
  16. Slikus Vaw
    Ah daum hopefully you can get a new book cause of the misprint
    LizardWizard and Pallys like this.
  17. Slikus Vaw
    So with dracothions tail I couldn't put a TQ in it cause a unit can't belong to 2 separate battalions cause DT doesn't include the TQ on its list of available battalions?
  18. Killer Angel
    Yes, Thunderquake is not included in the Dracothion
    LizardWizard and Slikus Vaw like this.
  19. LizardWizard
    Pallys likes this.
