AoS Dread saurion
Discussion in 'Seraphon Discussion' started by Bush4321, Jun 22, 2021.
Remain in AOS?
  1. Yes
    28 vote(s)
    90.3%
  2. No
    3 vote(s)
    9.7%
  1. Bush4321
    Bush4321 New Member
    Is there a place for dread saurion in AoS? Is forge world removing models from aos? If it stays what would you like to see on its warscroll? I hope it stays.
    Erta Wanderer likes this.
  2. Erta Wanderer
    in order
    we don't know. probably not, wthere will probably be no changes to the warscroll, and i do to
  3. Putzfrau
    I personally don't think it belongs in AOS unless you change its base size. It's base is so large it's extremely cumbersome to use and requires players really play loose with the way models move over terrain to allow it to do it's thing.
    With the way models move up and over terrain now it's even more problematic.
  4. valentine009
    valentine009 Member
    All they have to do is give it a rule that it ignores terrain less than 6' tall or something.
  5. Putzfrau
    Something like that would also work :) I find attaching arbitrary measurements to things with no standardization of use to not be super effective, but yeah something like that would definitely help.
    I still think its base is way too big ;)
    chefofwar likes this.
  6. Dread Saurian
    Yes I have a place
    It is a niche pick that gets use in tournaments but doesn't do very well overall though. with points cost not faq at the moment it can be considered that I am fairly efficient.
    Maybe but not the dread saurian. It is arguable that the dread is considered to be their most commercially successful product for aos that fw produces.
    Hence why like a year and a half ago they gave me my recent warscroll. Which to be honest if it does get a change give me a 5+ fnp and let my jaws hit on 3s and have the jaws have rend 3 or 4
    I'm not going anywhere little one your concern is appreciated. Your butchering of my name though....
  7. Tyranitar
    Tyranitar Well-Known Member
    I would like to see an updated plastic kit from GW with a manageable base. Make him mega gargant sized. Forge world is way overpriced and resin sucks anyway
    Dread Saurian likes this.
  8. Dread Saurian
    Sadly will probably not happen due to how forgeworld and gw works in all (in terms of what they make and release.) And honestly I thoroughly enjoy all of forgeworlds work using resin it's astoundingly well done and I've never had an issue with any models outside of horus lupercal and his stupid fuckinh world breaker (piece of shit)
  9. Kilvakar
    Kilvakar Well-Known Member
    I love the Dread Saurian, but I do have to admit that it's really hard to use just because of the base size. If you're playing on a table with so little terrain that his base size isn't an issue, you're likely having other issues because that just means that your opponent is probably just rushing you and destroying you turn 1.
    As for 3rd edition rules, I'm pretty sure that we won't be seeing any warscroll updates, just because it's Forgeworld and they rarely change their warscrolls. I do imagine a massive points hike, though, making him all but unplayable in the new rules.
  10. Nart
    Nart Well-Known Member
    Why won't you just make him fly and move through terrain?
  11. Kilvakar
    You absolutely can, but sometimes there's just too much terrain for him to find a place to land.
  12. Nart
    I think, AoS need way less terrain, than 40k and mostly flat. Just to be sure there's enough LoS block to hide heroes, and you are fine. At least, that's how we play.
  13. Dread Saurian
    I get that nart. And I get everyone's gripes with the gargantuhuge base it is absurdly large. And for a sense of reality check. There is no reason why the dread saurian can't go on a smaller base. But the best solution to the base issue currently with a lot of terrain. Is granting it fly. But since it is basically set up like a heirophant is why can't it have the gait rule that the heirophant has?
  14. Kilvakar
    That would be the best fix, just give it the ability to ignore terrain that wasn't completely impassable. The big base would still be awkward sometimes when placing it angled on some terrain pieces, but you could at least move him around.
  15. Dread Saurian
    Exactly the dreads entire mini set up is basically tailor-made for it to have a gait rule.
    Hell total war depicts a dread as basically being literally twice the size of a stegadon so why not?
  16. Titchy_Stryder
    Titchy_Stryder Active Member
    That’s it moved to “no longer available” on the FW site, glad I picked one up last year.
  17. Dread Saurian
    (Mashes hand into face)
  18. Tichi Huichi Raider
    Tichi Huichi Raider Member
    They actually just became available like a week ago and sold out in under a week, so Forgeworld seems to still be making them occasionally. Just check once a week and you can pick one up when they become available again.
  19. Dread Saurian
    like i said in the rumor sub. treat it like the dimacharron. it will come out when it comes out again
    Tichi Huichi Raider likes this.
  20. Titchy_Stryder
    No longer available is different to temporarily out of stock or temporarily unavailable.
    happy to be proven wrong in this instance though!
