8th Ed. Skink Squads of 50
Discussion in 'Lizardmen & Saurian Ancients Discussion' started by Danskman417, Sep 13, 2012.
  1. Danskman417
    Danskman417 Member
    so i been using 49 skinks and a skink chief in there with a BSB and the skaven pelt banner, anyone have any ideas on how to utilize this tactic and let me know if its a waste of point or not, so far it hasnt been terrible, seems to do well against most armies
  2. Arli
    Arli Moderator Staff Member
    A 49 skink unit is just begging for some Kroxigors to be added. They will be expensive, but it will be worth it.
  3. Danskman417
    Danskman417 Member
    hmmm, tell me more, im intrested, need something with a pop to it
  4. Danskman417
    Danskman417 Member
    how many kroxigors do you think?
  5. Qupakoco
    Can't go wrong with 3 Krox.
    I think those 50 skinks would fare you better as 5 squads of 10 skirmishers. They will likely perform much better than a giant block of squishy T2 lizards. Plus they are a bit more spread out so template attacks aren't as big of a worry. And your opponent won't possibly be able to target them all in one turn unless it's WE or something.
  6. liath
    liath New Member
    I'm not sure what you'd gain from running that many skinks, you'd get a lot of attacks (assuming they're at least 8 wide) probably 30 plus your chief but you'd be very squishy. If they hit anything hitting at a strength 4 (or even a strength 3) you're going to be looking at a lot of casualties!
    I'd look at either scrox units, smaller speedbump skink units or skink skirmishers/chameleons as mentioned above.
  7. captkurt
    captkurt New Member
    Dont listen to the nay-sayers....
    I run "all" skinks...not a Saurus in my army.
    I have 3 block units of Skrox, one with 50ish Skinks and 4 Krox. Immune to fear, immune to stomp, steadfast virtually to the last man.
    48 Skinks/4 Krox
    24 Skinks/3 Krox
    24 Skinks/3 Krox
    25 Skinks
    2x 15 Skink Skirmishers
    10 Cameleons
    Something key to remember about the Skrox unit...the Kroxigor count as the number of Skinks that they displace. This means that 3 Krox count as basically 2 full ranks of Skinks. Remember that when counting combat res, but especially for counting Steadfast.
    This is a little twisty in the new rules and I expect this to be changed in the new book, but for now this works great.
  8. Kharn The Betrayer
    Kharn The Betrayer New Member
    I'd be more interested in seeing how a horde of 24 Krox would do :)
  9. Danskman417
    Danskman417 Member
    thank you everyone that was all very helpful
  10. Scalenex
    That'd take up about all your special points in a 3000 point game. I plan to try an 19 strong unit before next Summer but I got a lot of assembly and painting to do.
